View Full Version : speed tech
pjz
08-31-2022, 06:04 PM
I have a 70 nova with speed tech road assault package with weight on front end it makes a snapping noise when turning the wheel
ryeguy2006a
09-01-2022, 09:26 AM
Did you try calling them?
09-05-2022, 07:59 PM
Hard to say but when I've heard that, it was the front sway bar moving side to side.
raustinss
09-06-2022, 02:32 PM
Is everything new ... ???
pjz
09-08-2022, 11:58 AM
Yes all new car has less than 100 miles on it
raustinss
09-08-2022, 01:21 PM
Very odd , have you tried jacking the car up to see if it changes .. and or have someone as another set of eyes or ears to help diagnose the situation
Sinnister69
09-10-2022, 06:06 PM
Stick a go pro under there and take it for a ride
Bthomas
09-18-2022, 07:28 PM
steering shaft and or u-joints binding up? or loose?
Rucumn
09-19-2022, 09:59 AM
Make sure your ball joints are drawn into the spindles.
raustinss
09-19-2022, 12:55 PM
Definitely a decent idea ... id suggest take the car off jack stands so the weight is on it , loosen and re torque all the fastners on everything you replaced, something is Definitely binding being as you told me it only happens when the weight is on the suspension
