View Full Version : Trunk Battery Breaker
srode
08-11-2022, 05:36 AM
I'm working on my trunk mounted battery starting/charging circuit plan and thinking I would like to just run a single 1/0 wire from the battery to the starter, and then run 4/0 to the 175amp alternator from the starter through a distribution block. I would like to use a blue sea 187 surface mount 200 amp breaker at the battery in the trunk. Think that would start and run the car without tripping?
Just 1 More
08-11-2022, 09:12 AM
I'm running mine off a 200 amp glass block style post mount fuse cranking a 10.2:1 Big Block
https://static1.pt-content.com/images/pt/2022/08/51964139308_17c3ed3bef_b-1.jpg (https://flic.kr/p/2naTNdm)20220327_090518 (https://flic.kr/p/2naTNdm) by F G (https://www.flickr.com/photos/153250783@N04/), on Flickr
srode
08-11-2022, 09:23 AM
Thanks, so you have the power to the body and the starter both on that 200amp fuse? Sounds like it should work then.
Tsaints1115
08-12-2022, 05:06 AM
That's what I'm running, bit larger cable though.
201421
