    Results 1 to 5 of 5
      Jul 2012
      Louisiana
      5th gen front and rear disc to 2nd gen F-Body....is there a kit?
      i have a complete 99 Trans Am that id like to do a front and rear brake swap to my 72 T/A. Are there kits or how-to's available. Been searching the forum for a while and all i see is C5 kits. i already swapped the rears to S10 blazer discs but would like to go bigger.
      Aug 2005
      Hamilton, NJ
      That's a 4th gen
      BRP hot rods used to sell parts to use the fronts. Mose people elect to use the bigger c5 stuff.
      If you are removing the blazer discs, and they clear 15s and staggered shocks I might be interested
      Scott from NJ.
      Vent Windows Forever! ...
      If you use 99 rear disc brakes you will need to lefts (I believe) so it will clear the staggered shock setup.
      I would post over on NastyZ28.com and ask your question. Wealth of knowledge over there.
      Sep 2013
      Houston, TX
      I have Blazer rear discs on my '72 Olds 442, I think the Blazer parts were from 2001 model year. They just barely would fit inside a 15" Olds SSIII rim in a mock-up. I ultimately went with 18" rims from US Mags so I never saw this all the way through to final install but it looked do-able!
      Rodney
      Rodney Meyers
      72 Olds 442 Rest-mod clone
      May 2013
      Colton Ca.
      Bigbrakeupgrade.com carries the brackets I believe.
      Ahmad B.
