    Results 1 to 3 of 3
      Jan 2009
      Spartanburg,SC
      Using 5th gen Camaro console guages in a 2nd gen Camaro
      I don't know if there is a thread for discussion already and if there is maybe someone can direct me. I have the console and guages out of a 5th gen and I am replacing my 2nd gen console and want to know if anyone has made the guages work with the sbc setup or if there is an aftermarket wiring harness to do this.
      Richard Parker
      2nd Gen. F-Body Lover
      Jul 2008
      Unless you want to spend a lot of money on electronics and add unnecessary weight to the car I'd look into replacing the factory gauge guts with sbc style gauges. They're 120 degree sweep gauges, there's a lot of options out there, you just have to figure out mounting and needle options.
      *Jeff*
      Sep 2009
      Atlanta Ga
      Classic instruments converted my 5th gen pod to analog so I could use senders for each function. I will not post cost but its not cheap. Classic instruments does great work.
      Tim
    Tags for this Thread
