View Full Version : New to Pro-Touring Site
john3416
06-17-2022, 07:53 PM
[SIZE=4]John here, and new to this site. I am making and upgrade/change to my 68 Camaro. One addition so far, I will be adding E90 BMW seats to my car. :headbang: I'll attach a photo of my wiring that I am using. Drivers seat with computer. Remove red/violet and red/brown, both browns and the two can wires, orange and orange/green from from connector. Cut and splice can- G to both brown wires leaving/adding a 6" tail (20-22 wire)to attach to a 5x5x5 pulse generator, at the GRD position. Splice a orange wire, #20-22 to the can OG+ wire and connect to the PG at the OUT pin. Splice both red wires, and attach a small red wire, 6", (#20-22 red) wire and connect to VCC . Your drivers seat should not time out when the ACC or IGN is on.
200549200550
200551
[ATTACH=CONFIG]
Has anyone on the site completed the seat installation/mounting that may have pictures?
john3416
06-17-2022, 07:58 PM
Posted wrong picture. The Slash Drags should be my 68 Camaro.
john3416
06-18-2022, 07:27 PM
This is my Camaro that I am working on/driving.
200559
minendrews68
06-24-2022, 01:24 PM
Welcome, and yes, we love pictures...
john3416
07-20-2022, 03:21 PM
Pieces I made to intall the E90 seats.
1/2 by 2.25" pieces of plate steel 3/16 thick. Drilled 2 each 5/16 holes 1.5"'s apart in each plate. (2 sets) Also cut 3/4" rod 1" long, drilled 5/16 hole in the middle to support the rear mounting brackes, 4 each. Used 5/16 X 1.5" long bolts to mount seats to floor board.
201062
Installed seats. All power options will work but the MEMORY for operator 1 or 2 (needs can system extras). Did not use heated seats or airbags.
201063
200559
