Results 1 to 8 of 8
Thread: A Body Spindle Options
06-09-2022 #1
- Join Date
- Nov 2006
- Location
- Rochester, NY
- Posts
- 177
As time allows I'm going to take a run at resurrecting our mothballed 1966 LeMans project this summer. Step 1 is to get it rolling so I can move it the 3 miles from my folks house to my shop.
The goal for the car is to be a nice, competent driver. Not a high-dollar build and any kind of autocross or HPDE is not really the target but who knows. I'd like it to go/handle/stop on an equivalent level of a modern sport sedan (like 540i, not M5). Given those goals I won't be doing anything too involved or expensive like frame reinforcements or full coilovers. But proper geometry is important to me and I have to buy spindles and control arms anyway so I might as well optimize that. The stock drum spindles, hubs, and steering arms were unfortunately scrapped many years ago in anticipation of the B-body tall spindles that were the hot setup at the time. Right now I'm starting with bare frame rails from the firewall forward. I have not settled on which control arms I will use yet but that decision will be based on similar criteria of best bang-for-the-buck without using something with an unsafe level of quality.
As I understand it geometry-wise these are 3 main improvements to be made:
1. Increase caster by moving upper ball joint back and/or lower ball joint forward
2. Improve camber curve by increasing the distance between the effective centers of the upper and lower ball joints
3. Reduce or eliminate bump steer by moving the pivot point of the outer tie rod end up (and maybe outboard too?)
In addition to these I'd also like to lower ride height. I am a fan of the idea of having modern unit bearings for their maintenance, strength, and wheel fitment advantages but I don't consider this a must. I'm not too concerned about brake compatibility as I have a plan that will require custom hardware no matter what.
The options I'm aware of are:
1. Stock spindles or stock-height drop spindles. I can use +0.9" upper ball joints to increase effective spindle height and +0.5" lower ball joints for even more height as well as supposedly decreasing bump steer. Global West also has very affordable steering arms to fix bump steer and quicken steering (a very attractive benefit). But if I combine the Global West steering arms with the +0.5" lower ball joint does it move the tie rod up too much and ruin the bump steer benefit? If so maybe one of the rod-end style bump steer kits could bring it back to optimal?
2. Speedtech AFX spindles. Benefits of light weight and unit bearings. Fixes all geometry but pretty tough on the budget when compared to other options - especially with the aluminum steering arms too.
3. CPP "C5" iron spindles. From the limited information available these are tall but maybe not tall enough to be optimal? Steering arm bolt holes seems to be in "stock" locations so could combine with +0.5" lower ball joint or Global West steering arms for bump steer correction?
4. Church Boys Billet Spindles. I just found out these exist and almost no information on their site. It probably doesn't matter because they are really expensive.
What else is out there? And what opinions or data do the experts here have on the above options?
