View Full Version : Oil pan for 2nd gen
Alponcho
05-29-2022, 08:36 AM
What's the best option for stroked LQ4 (408) in second gen with Ridetech True Turn? Mostly street and autox. Would the Holley 302-3, GM fbody, and Mast LS stroker pan all work for this application? Other options? I know subject of oil pans has been covered here and elsewhere, but getting conflicting information.
79 Camaro
05-29-2022, 01:20 PM
I've used the 2002 Fbody pan on a few Fbody LS swaps. One was a LS2 sleeved and stroked to 427 cubes. I didn't put it together but I believe they had to shim the windage tray down to clear the stroker crank. On my non-stroked LS engines I had to trim the windage a bit at the front.
ORBandit
06-02-2022, 07:46 AM
I used a 2002 Fbody. Mine is a stroked 427. Holley hangs way too low.
Poncho72
12-31-2022, 04:58 PM
4th Gen F-body, perfect fit and ground clearance. Only possible drawback is the loss of 1/2 quart oil capacity - 5.5 versus 6 qt.
