    Results 1 to 5 of 5
      Nov 2016
      Sulphur, La
      69 Camaro: Squaring subframe and quadralink
      Curious if you guys have input. I will be squaring everything up without an engine in the car and with the car on jack stands. I am wondering if you have seen differences in the measurements once the car is completed & on tis wheels vs the way mine will be done. Obviously the car will settle vertically some and wheelbase will change slightly but will the cross measurements change?
      Sep 2010
      Beach Park IL
      I'm sure it changes.
      I'm also sure you will never see it on a tape measure. I typically do it on a two post lift and my alignment guy rarely has to make adjustments for thrust angle.
      Donny
      Nov 2016
      Sulphur, La
      I believe you are most likely correct although I'm pretty talented with that plumb bob!
      Mar 2022
      Are you still selling? If so I can send you my number to discuss.
      Nov 2016
      Sulphur, La
      It’s one of those situations where I don’t want to sell but I have my toy funds stretched thin with too many projects so I probably would sell it.
