Results 1 to 20 of 24
Thread: Wheel Fitment On 69 Mustang
01-05-2006 #1
Wondering if anyone knows the widest wheel and tire combo that will fit on the rear of a stock 69 mustang.
Silver69
01-06-2006 #2
- Join Date
- Jul 2005
- Posts
- 76
I've seen a 69 Boss 302 with elevens with 315/35s and it filled every inch. The inner housing had to be modified and the outer lips rolled. The car may have had other modifications to the suspension.
Originally Posted by silver69
I've also seen ten inchers with 295s with slightly more than 6 inches of backspacing (metric Cobra Rs). The owner also had to perform the same modifications to the inner and outer wheelhouse.
There has been a fair amount of articles recommending a maximum of a 9.5 inch wheel with 275/40s. This is supposed to fit without any modifications on most cars and this may be the best compromise if you're building a daily driver.
I may end up going with a 9.5 inch rim with 5.75 inch backspacing and then try a 295 tire first and move down to a 285 or 275 depending on how much room I have.
01-06-2006 #3This might shed some light on the question. Clickey
W.William Rouleau
Project PonySnake - '67 Mustang Fastback
01-06-2006 #4I wish I had something to contribute, but I'm actually interested in the same answer. I know you can get a 275/40 back there with the right backspacing and and a little bit of rolling the fender lip, which is what I'm probably gonna go when it comes time for new tires.
01-06-2006 #5
- Join Date
- Jul 2005
- Posts
- 76
This verifies what the magazine articles report because it shows 275s on 9.5s.
Originally Posted by 67Sally
Beyond that commonly accepted size, the widest on the chart is a 9.5 rim with 6" inch backspacing and 285s. Note that it required some "tweaking" to the wheelwells.
01-06-2006 #6
