cutlassmann
03-07-2022, 08:47 AM
RideTech ShockWave v3.0 Air ShocksRideTech brings you the latest refinement of the original ShockWave in the form of these ShockWave v3.0 air shocks. They use double-convoluted air spring bellows to achieve the load capacity required for these installations.
RideTech CoolRide SystemsThese CoolRide systems have the greatest application coverage and versatility of all of RideTech's systems. They will raise and lower the vehicle, improve the handling, and offer a terrific ride. On a front system, the shock is usually relocated to the outboard side of the lower control arm. A weld-on bracket mounts the top of the shock to the frame rail. On a rear system, the air spring and shock absorber will normally go in the stock locations. These CoolRide systems consist of an air spring, a shock absorber, and all of the necessary mounting bracketry and hardware.
RideTech RidePro E2 Air Ride Suspension Control AirPod Dual Compressor Systems
Everything is new system been installed but never used E2 is a old system but can be upgraded this is a great deal. 1700.00 Firm.
197848197847197846197849197850197851197852
