Results 1 to 6 of 6
Thread: 18" CCW ID measurements
09-24-2004 #1
Gentlemen, I thought a couple of guys were running these wheels (CCW 18" 3 piece Classic) and I have a question. I need to know the ID of the wheel hoop. The reason I ask is that there is potentially an interference problem with the tie rod end on my IRS. I have made a template based on 16" ID and there will certainly be contact. Can anyone confirm this number for me? This will be an 11" wide rim.
Thanks in advance, Noel.
09-29-2004 #2Anyone?
Anyone one with any kind of 18 rim? I would certainly appreciate an inside diameter measurement. Thanks for the help.
Noel.
10-01-2004 #3Noel, I have a pair of C5 rears that I can measure tonight- but why don't you call CCW? They should be able to give you the info you need. I'll get the C5's ID tonight and post it, but I don't know how accurately that will cross to any other rims.
Brian D
Snotty Bimmer driver.
10-01-2004 #4Thanks alot Brian, appreciate it.
Chill, Noel
10-02-2004 #5Or the next night! At the inner edge of the rim they are 17 7/8" diameter, with a steady taper down to 16 1/4" at the hub mounting surface plane. HTH.
Brian D
10-02-2004 #6Thank you very much. I actually took your advice and just called, their answer was remarkably similar to yours. I really do appreciate the help Brian.
Chill, Noel.
