View Full Version : Rubber inserts in Holley clamshell mounts
streetk14
01-27-2022, 08:11 AM
Just wanted to see if anyone has experience using factory style rubber motor mount inserts in the Holley/Hooker clamshell swap mounts. I’ve always stayed away from rubber, but my thought was that maybe it’ll be more durable in this application.
dontlifttoshift
01-27-2022, 09:10 AM
You mean these, Anchor 2292?
Yep, use them a lot. Have not had a failure yet and I am pretty hard on mine......and they are dirt cheap.
streetk14
01-27-2022, 10:00 AM
Yep, those are the ones. Figure if I can reduce some NVH without them failing, why not. The motor is probably going to make 500 WHP if that matters. Nothing too crazy.
