View Full Version : 1969 Pro Touring Camaro LS 427 DSE
blown32
01-12-2022, 08:38 AM
[B] Up for sale is my Beautiful Custom Grey 1969 Camaro with Award Winning Custom Leather Interior by Ron Mangus. 187,000.00 Must see to be appreciated!
Car is located in Prescott Arizona
*****SOLD*******
1969 Camaro all new steel body with clean 1969 Camaro Arizona Title in my name
Detroit Speed & Engineering weld in sub-frame connectors
Detroit Speed & Engineering narrowed stainless fuel tank & pump
Detroit Speed & Engineering fuel tank access door
Detroit Speed & Engineering Trunk close-out exhaust kit
Detroit Speed & Engineering T-56 Transmission Cross member
Detroit Speed & Engineering Mini tubs
8-Point weld- in cage
Front & Rear flush mounted stock clear glass
Side marker lights shaved
Shaved drip rails
Front & Rear bumpers narrowed & tucked w/ shaved bumper bolts
Smooth Firewall
2” Steel Cowl hood
Custom built front spoiler
ENGINE & TRANSMISSION:
LS-2 with LS7 Darton sleeves
Precision race components 285cc heads 199-PRCLS76B285
Titanium intake valves
Manley severe duty s/s exhaust valves
Manley Platinum series pistons
BTR-LS7 micro-polished rocker arms
BTR- Chromoly pushrods
Chevy performance LS7 lifters
Howard LS hydraulic roller cam
JP performance roller timing chain
Howard cams valve spring & retainer kit
Eagle 4340 crank
ARP-Cylinder head studs
GM LS Starter
Wegner Front drive
Wegner 2pc hidden coil valve covers
Shaun’s Custom Billet Intake
Frank’s Custom Cold Air return
Holley Sniper 102mm Throttle Body
AUS 62lbs injectors
PSI Wiring harness & ECU
Stainless American Racing Headers 2” primaries
Custom Tig welded 3”brushed Stainless exhaust with V band clamps
Borla Pro XS mufflers
Bowler T-56 Magnum, Close Ratio 6 Speed Transmission
Quicktime Bellhousing
Centerforce aluminum flywheel
Centerforce Dual friction clutch assembly
McLeod Hydraulic Clutch master Cylinder
Be-Cool aluminum radiator w/ dual Spal 11” electric fans w/ black billet reservoir
Vintage Air Gen IV Magnum Heat, Air & defrost system
Gen IV streamline Black 3 knob vertical
REAR SUSPENSION:
Detroit Speed & Engineering Quadra Link
Detroit Speed & Engineering rear tow hooks
Detroit Speed & Engineering sway bar
Koni Coilovers
Speedway engineering 9” rear end narrowed to 56”
Dutchman 31 spline axles
Ron’s rear ends 3rd member
370 tru-trac
FRONT SUSPENSION:
Detroit Speed and Engineering Hydroformed subframe w/ rack & pinion
Detroit Speed & Engineering Adjustable Coilovers
Raceseng Front Tug
BRAKES:
Wilwood Black Master Cylinder
Wilwood Black proportioning valve
Wilwood Aero 6 piston Front Calipers -14” Front 2 piece slotted
Wilwood Aero 4 Piston Rear Calipers Rear-14” E-Brake 2 piece slotted
WHEELS & TIRES:
Forgeline Rear- 18x12 GT3C with Toyo 335/30ZR18- Trac Tire
Forgeline Front-18x10 GT3C with Toyo 275/35ZR18- Trac Tire
INTERIOR:
Ron Mangus custom leather interior
Custom built center console
Cobra Misano anniversary seats w/ pure carbon fiber backrest
Rear seat delete
Billet Specialties steering wheel 14” D-Shape Formula
HMS Motorsports –SCHROTH 4-point seatbelts
Kenwood DDX6706S monitor w/DVD receiver
Kenwood Speakers w/ tweeters
ARC Stereo Amplifier
Flaming River tilt column w/ 1”DD to ¾ polished stainless steering shaft
American Auto wire- Classic Update Series wiring
Guard Dawg – PBS II Push button start
Nu-Relics power windows
2 Vintage Air Proline brushed double louver bezel
Modo Innovations truck release kit
Detroit Speed and Engineering custom dash insert
Auto Meter Ultra Lite II dash instruments
Detroit Speed and Engineering electric RS headlight doors
Detroit Speed and Engineering Black Billet Aluminum battery mount
Recessed battery box in trunk
Optima battery
Full length battery cables
Battery shut off
DSE /Rock Valley Stainless fuel tank W/pump
Anvil carbon fiber closeout panel
Full Dynamat including doors and roof
Fesler Billet LED Driving /Turn/ lights
Fesler tail lights
Digi-Tails LED Sequential Tail Lights
Detroit Speed and Engineering 7 Speed wiper motor
Stainless hand formed brake lines
Ride Tech billet locking cap
Ring Brothers Door Handles
Ring Brothers Hood Hinges
Ring Brothers door strikes
EM door jam vents
Black exterior door locks
E-Stopp Emergency Brake
JTrevor
01-12-2022, 12:23 PM
Badass! Love the interior
blown32
01-12-2022, 02:24 PM
Thank you
blown32
01-15-2022, 04:34 AM
Some under carriage shots.195548195549195550195551195552195553195554
jeff-san
01-15-2022, 08:08 AM
awesome Camaro.... any idea what the RWHP is? how many miles are on the build? great description. I hope it sells quickly...
blown32
01-15-2022, 01:41 PM
Thank you. 550 RWHP and 127 miles at this time.
ZZ430
01-15-2022, 06:43 PM
Liking that car a lot! Clean, clean.
Good luck with the sale.
blown32
08-17-2022, 01:46 PM
Bump...New Price. SOLD
badmonza
08-18-2022, 04:55 AM
Do you take trade ins?
blown32
08-18-2022, 05:11 AM
The car is now at www.choiceauto.com
Ask for Mike 928-468-1970
You can ask Mike, he might do a trade.
Thank you,
John
badmonza
08-18-2022, 06:07 AM
Thank you,
John
Will do. Thanks!
blown32
08-22-2022, 04:05 PM
Sold
badmonza
08-23-2022, 08:41 AM
Congratulations and Congrats to new owner! That Camaro is one of the nicest out there!!!
