View Full Version : hard Fuel line
hotrod56
01-05-2022, 03:04 PM
Suggestions on 1/2" hard fuel line.
Aluminum
Steel
Stainless
Copper-nickel (can only find one distributor - stop shop. Earls only makes up to 3/8 and I wonder why)
Why one option over another?
Where would you get it?
dhutton
01-05-2022, 03:46 PM
Heres another source of nicopp. That’s my choice for fuel hardline.
https://www.summitracing.com/parts/sum-220220-25
Don
icemanrd19
01-05-2022, 09:34 PM
you know that is pretty nice. Making my stainless steel line was such a pain
Don
Bigblockscott
01-07-2022, 11:47 AM
I used aluminum on my car for fuel, I'm using nicopp for brakes, and tranny cooler lines.
Motobrewmaster
01-08-2022, 05:34 AM
I used NiCopp for my fuel lines and found them to be very easy to work with. I actually used a stock line as a model to bend up the NiCopp, which made for a nice clean fit. The NiCopp is also less reactive with fuel and the road grime that will inevitably contact the outside of the lines. There is a-lot of info on the site about it if you search. I also recommend the Rigid tool flaring tool if you are going to use AN fittings.
BStocklin
01-08-2022, 04:53 PM
I got nicopp for basically everything. Seems pretty easy to make look nice
joeko23
01-09-2022, 10:04 AM
This was my first time doing brake/fuel lines. Used nicopp for everything. It was super easy to bend and flare. Also, so far no leaks. Really made it a pleasurable experience.
Kenova
01-24-2022, 12:37 PM
I used aluminum for my fuel lines, but at the time I don't think NiCopp had been invented yet LOL.
I have since used NiCopp on smaller jobs and will use it rather than aluminum next time.
NiCopp also polishes up nice. Use some fine polishing compound then apply a bit of wax.:cool:
Ken
BonzoHansen
01-24-2022, 04:26 PM
How does it age? I've seen some in people's cars turn greenish
Ken
Kenova
02-01-2022, 07:12 PM
I haven't had any problems with tarnishing. The wax may have helped with that. I do get a bit of haze on it but a quick buff with a clean cloth brings it back.
Ken
