View Full Version : 1962 Bel Air
Austin609
12-20-2021, 04:58 PM
Hey guys, I decided to give my 62 some love. 10 years ago I got it out of my dads garage where is has been setting for 30 years or so, put a 496 in it, picked up dirt bikes as another hobby (which consumed me and is still trying to pull me back ha), and parked the car only driving it 1 or 2 times a year since.
In September I decided I wanted to change it up a bit, take it from the old school look it had going on and turn it into a Pro Touring ride.
I've made pretty good progress since then.
The car before I took it apart.
194796
194797
Taken her apart.
194798194799194800194801194802194804
Austin609
12-20-2021, 05:06 PM
Fully welded the frame and added reinforcements to the X and front frame rails.
Cracked Frame
194806194805194807194808
X Reinforced
19481719481619481519481419481319481219481119481019 4809194818194819194820
Front frame rail reinforcement.
194822194821194823
Austin609
12-20-2021, 05:13 PM
Frame painted and suspension test fit.
194825194824194826194827194828194829194830
TUBED
12-20-2021, 05:23 PM
Are the rear Black steel wheels that came off the car 15 x 8 with a 275 60 15 tire? It's nice looking combo your making good progress.
Austin609
12-20-2021, 05:29 PM
Thanks. Yes they are, 15x8 and MT Drag radials........................................... .................................................. ......
TUBED
12-20-2021, 05:51 PM
Thanks for the info and do you know the manufacture & backspacing on the rear wheels? Sorry about the questions I tried to PM but couldn't as I'm looking for some with a 4.5" rear spacing and GM bolt pattern. Thanks Gerald
Austin609
12-20-2021, 06:03 PM
I’m 99% sure that is what the backspacing is on these. I don’t remember the brand, I bought them from summit 10 years ago or so. Maybe US wheel or Coker. I’ll measure them tomorrow if I get a chance.
TUBED
12-20-2021, 06:07 PM
If you have time that would be great. Gerald
wfo guy
12-21-2021, 10:09 AM
Good start.
Austin609
12-21-2021, 02:24 PM
They are 4.25in backspacing. I'd say they are these Cokers.
194848
TUBED
12-21-2021, 07:12 PM
Austin thanks for checking will you be changing the wheel combo? The OE style interest me, you may PM (private message) me if you like to keep build thread from getting off track. Thanks Gerald
39 chev
12-21-2021, 08:17 PM
Looking good. I'm just starting on a 1958 Bel Air project. I did some reinforcing around the X, but not as much as you! I have a thread started in the Suspension section.
I'm curious if you are going to try to run the exhaust out the rear? Gets pretty tight around the rear end!
Austin609
12-22-2021, 04:13 AM
No. It’s going to exit before the rear tires again.
Chirus
12-22-2021, 06:26 AM
Hell yes, More X-Frame goodness.
cl08
10-31-2022, 12:19 PM
Nice!!! I just bought me a 62 Hardtop. A lot of work to the X frame. You plan adding more power?
ProTouring442
11-01-2022, 12:25 PM
Reenforce the rear lower control arm mounts! They frequently aren't welded that well to begin with. A good first to second shift can break the right one loose. Believe me, I know!
Cramer4918
11-29-2022, 06:58 PM
Good progress so far! I like how you are stiffening up the X-Frame. I have a '61 Biscayne I am working on currently. I am looking forward to the progress of your build.
eversaul86
12-01-2022, 09:12 PM
Great build! Love the fab work. Can’t wait to see the progress.
Martin
