    Results 1 to 6 of 6
      Oct 2009
      Rear caliper bracket help
      I have a conversion setup from big brake upgrade for my moser 12 bolt with ford ends thats going in my 69 camaro
      It uses brembo style calipers from late model corvettes and camaros
      I got a set of used rear brembos off of a 2016 camaro SS and although the bolt holes line up
      The mounting plate is too thin
      I emailed scott but they are in the middle of a move so i figured i would ask here too
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Oct 2011
      It looks like your using stock hardware. Since your bracket isn’t stock you need a shorter bolt and one that’s fully threaded. You have plenty of thread engagement there into the caliper.
      Oct 2009
      True but at part under the head of the bolt is thicker and used as a locating dowel so i really cant use a fully threaded bolt
      LS3
      Oct 2011
      Did you put on the rotor? Maybe it needs space to be shimmed out? But I still think you need a shorter bolt.
      Oct 2009
      I havnt yet but that could be the reason
      If not do they sell shorter bolts with the locator?
      LS3
      Oct 2009
      Problem solved there was a bag hiding in the packing material that has all the bolts i need
      LS3
