View Full Version : Moving battery to trunk
5spd540
11-06-2021, 04:53 PM
My question what size wire do I need to move my battery to the trunk of my car?
79 Camaro
11-06-2021, 05:55 PM
I use 02 gauge for both positive and negative. If you have a big draw components you could go up to 00.
joeko23
11-07-2021, 05:46 AM
Get a 5th gen Camaro positive and negative cable. Used it in my build. Great oem quality and I think it’s a 1/0 cable. Also comes with 2 built in fuses you can use with amps etc.
https://www.ebay.com/itm/2011-2015-Camaro-SS-ZL1-LS3-L99-Positive-Negative-Battery-Cables-USED-OEM-GM-/384151690139?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0
5spd540
11-10-2021, 12:07 PM
That’s a pretty good idea
JustJohn
11-10-2021, 01:23 PM
Any idea on the overall length of the Camaro cables?
79 Camaro
11-10-2021, 01:39 PM
The other thing I like to do is use isolators that bolt thru the trunk sheet metal. I don't care just just a grommet to protect the cables.
joeko23
11-11-2021, 05:37 PM
I used it in my build. It was plenty long enough for me. I ran it inside the car, then through the firewall (between the inner and outer passenger fender) just like the heat/AC lines, then to the starter. Like I said plenty long enough.
5spd540
11-11-2021, 11:13 PM
A 2010 camaro positive battery cable is 246inches long.
JustJohn
11-12-2021, 04:43 AM
Sounds like it might get me to the firewall, which is what I need. My car is 18 ft long...
Jim Streib
11-16-2021, 09:29 AM
246 inches ????? That's 20.5 foot.
Jim Streib
11-16-2021, 09:35 AM
The gauge of the wire will depend on how much current you are wanting to get through it.
One might be able to run a front to back 4 gauge cable on a high torque starter turning over a low compression motor but that wire will not be enough if a stock old style starter is used on a high compression motor.
I've seen cars with 4 gauge and others with 1/0 and it depends on what is needed. You can go to the 1/0 even though you might need a 4 gauge though.
Also be aware there is copper clad aluminum wire out there (CCA for short) and then there is oxygen free copper wire (OFC).
A 1/0 OFC wire is close to being like a 2/0 CCA wire. The aluminum wire needs to be larger in gauge than copper for the same ampacity.
In other words the 1/0 CCA wire is cheaper than 1/0 OFC but the ampacity is lower.
Oh, and if you can, properly protect the cable with the proper sized fuse and even if it's a sealed AGM battery, still put it in an enclosure vented to the exterior of the vehicle. AGM batteries can vent explosive fumes just like flooded cell batteries.
Info I've put together through the years:
https://www.flickr.com/photos/121766713@N04/albums/72157656656084141
Jim
