    Results 1 to 5 of 5
      Jan 2014
      Austin, TX
      How are you C10 guys mounting bucket seats?
      My daily driver is an LS swapped '72 C20 Suburban. I just ordered a set of custom upholstered Cobra LeMans seats to replace the front bench. I'm curious how you guys with C10 race trucks are mounting buckets in the front. I know Corbeau and TMI both offer full width brackets that accept two buckets and sliders, but I'd prefer the space between the two seats to be open as I dont plan or running a center console.
      Appreciate the input!
      1972 C20 Suburban
      1964 Corvette Coupe
      Nov 2016
      Sulphur, La
      Mine (not done by me) are simply bolted through the floor. They are actually solid but not a great idea. I am just going to weld a plate under the floor to reinforce the areas where the mounts are.
      On my C10 project before I finished the floor pan paint I placed the seats and drilled the holes. Then I took pieces of 1/8" sheet metal about 2" square and welded it to the bottom of the floorplan and drilled thru the 1/8".
      Jun 2011
      Brooklyn, NY
      I drilled holes through the floor, and used these
      https://www.tanksinc.com/index.cfm/p...rod/prd827.htm
      Jan 2014
      Austin, TX
      perfect, thanks for the input!
      1972 C20 Suburban
      1964 Corvette Coupe
