View Full Version : Pushrod length
Sinnister69
07-31-2021, 02:35 PM
Bone stock ls3 besides summit 8707R1 cam with .600@ lift on both lobes
And johnson 2110 lifters
Is it normal to measure varying pushrod lengths?
Using ms racing ls pushrod length checker and checking springs
I did the odd bank today and these are my results
191008191009
Sinnister69
08-01-2021, 08:30 AM
Figured i would try some math
Is it good to add up all my intake #’s with the .035” preload and then divide by 4 to get the average pushrod length then add or subtract that average number to each individual intake to see if i am within the recommended .035” preload +/- .010”
This method i became well in spec
Same was done with exhaust
Once i do the even bank i will divide by 8
But doing this experiment has my intake length at 7.3465” and exhaust at 7.3621”
I can easily order custom length pushrods191033
dhutton
08-01-2021, 10:42 AM
Are you checking and verifying the wipe on the rockers?
Don
Sinnister69
08-01-2021, 12:57 PM
Thats my next step
dhutton
08-01-2021, 01:20 PM
Hmmm I thought the wipe determined the pushrod length. Admittedly it’s been a while and I dont do this very often.
Don
Sinnister69
08-01-2021, 03:45 PM
Its an ls3. Bolt down the rocker to zero lash on the checker then add preload to zero lash length so i dont think u need to check wipe
