View Full Version : Sniper Tuning
elwaupo
07-05-2021, 09:27 AM
I have a Holley Sniper on my relatively stock SBC and sometimes when I step on the pedal it backfires(or something like that), any clue to what that is?
SSLance
07-05-2021, 09:42 AM
Are you using the Sniper to control your ignition timing?
elwaupo
07-05-2021, 12:06 PM
I’m using the large cap HEI distributer, i remember setting the timing when I installed it, I went just the basic setup. I’ve been thing of buying the Hyper Spark if that would help
Tsaints1115
07-05-2021, 12:09 PM
Sounds like a timing issue. Any chance you're off a tooth on the cam?
dontlifttoshift
07-05-2021, 12:59 PM
Backfires? Like out the exhaust?
Or does it sneeze through the throttle body?
What happens to AFR when you step on the gas and this happens?
elwaupo
07-05-2021, 01:18 PM
Sneeze and I think the AFR drops a bit. It almost or sometimes dies so I keep my foot on the throttle to keep it from dying. I disconnected the battery and reinstalled the set up and took it for a test drive and it sneezed
elwaupo
07-05-2021, 02:47 PM
Highly doubtful my timing chain would be off tooth, motor is low mile, I’m thinking it’s timing on the distributer
Tsaints1115
07-06-2021, 06:43 AM
I accidentally installed the distributor 180* off in my 351W. It started but ran like s**t doing some things similar to what you describe. I realized my mistake and spun it around and it was golden.
elwaupo
07-06-2021, 04:42 PM
Mine is non timing controlled
andrewb70
07-06-2021, 06:16 PM
Send me an email with your current global config file.
projectgattago at gmail dot com
elwaupo
07-07-2021, 07:07 PM
I’m out of town this weekend but I will next weekend, thx
