View Full Version : GM A body sway bar end link suggestions
Lickity Split
06-18-2021, 05:02 AM
I might be over thinking this but I have a 1971 Olds Cutlass with a SC&C AFX suspension kit and Hellwig sway bar with Hellwig end links. While I was under it over the weekend I noticed one of the sway bar end links was missing. Only thing left was the mounting bracket and collar on the A arm. The rod was broken off clean at the collar and more puzzling was the rod itself was gone and the collar looks like it led a hard life. The car is not raced or driven hard at all.
Anyway, suggestions for end links would be appreciated.189819189820
Lonnies Performance
06-18-2021, 11:47 AM
Can you adapt something like this? The rod end will allow more movement instead of the bushing... you can likely reuse the mounting bracket with a few spacers.
https://www.umiperformance.com/home/product/1993-2002-gm-f-body-sway-bar-end-links/
189824
chevelletiger
06-19-2021, 04:02 PM
It looks like the bushing was over tightened and the mount went into bind.
