      Jan 2016
      Manitoba
      GM A body sway bar end link suggestions
      I might be over thinking this but I have a 1971 Olds Cutlass with a SC&C AFX suspension kit and Hellwig sway bar with Hellwig end links. While I was under it over the weekend I noticed one of the sway bar end links was missing. Only thing left was the mounting bracket and collar on the A arm. The rod was broken off clean at the collar and more puzzling was the rod itself was gone and the collar looks like it led a hard life. The car is not raced or driven hard at all.
      Anyway, suggestions for end links would be appreciated.Name:  IMG_3816.jpg
Size:  361.9 KBName:  IMG_3817.jpg
      Mar 2020
      Can you adapt something like this? The rod end will allow more movement instead of the bushing... you can likely reuse the mounting bracket with a few spacers.
      https://www.umiperformance.com/home/...bar-end-links/
      corona,ca.
      It looks like the bushing was over tightened and the mount went into bind.
      72 chevelle.
