View Full Version : How to install an Air Fuel Ratio Gauge? 1968 Camaro
majj35
05-24-2021, 02:02 AM
Sorry, dumb it down for me.. 0 electrical experience especially on classics.
I'm looking to get an AFR gauge to monitor from Autometer or others. I have Autometer gauges now, the basic Temps, Oil, Volts.
How do you hook up an AFR gauge and have it read accurately? thanks. (LS engine)
ORBandit
05-25-2021, 04:43 AM
Easiest way is to buy a gauge/kit. Insert wideband 02 and wire gauge. It's less hassle to leave the factory narrowband in-place for ECU/PCM function, and the wideband for tuning/reference.
I've had good luck with Innovate's stuff of the years.
https://www.innovatemotorsports.com/
andrewb70
05-25-2021, 06:48 AM
What ECU are you currently using? Do you want a wideband O2 sensor kit or narrow band?
majj35
05-25-2021, 06:55 AM
Unfortunately, not sure which. Anyway to find out?
andrewb70
05-25-2021, 12:26 PM
Are you using a GM ECU or something like Holley EFI?
majj35
05-25-2021, 12:41 PM
GM ecu
andrewb70
05-25-2021, 12:52 PM
GM ecu
The GM ECUs use narrow band O2 sensors. If you want the gauges to match, you can get one of the Autometer wideband gauges:
https://www.autometer.com
GO to Gauge type and select "air fuel ratio."
You will need to add a bung to your exhaust to mount the O2 sensor.
