      Feb 2017
      Jeddah, KSA
      How to install an Air Fuel Ratio Gauge? 1968 Camaro
      Sorry, dumb it down for me.. 0 electrical experience especially on classics.
      I'm looking to get an AFR gauge to monitor from Autometer or others. I have Autometer gauges now, the basic Temps, Oil, Volts.
      How do you hook up an AFR gauge and have it read accurately? thanks. (LS engine)
      1968 Camaro SS | LSx 364ci
      T-56 | RT StreetGrip | RT Steering Kit | TRSD Disc Brakes | Wilwood Dual Piston
      Jun 2016
      Upstate NY
      Easiest way is to buy a gauge/kit. Insert wideband 02 and wire gauge. It's less hassle to leave the factory narrowband in-place for ECU/PCM function, and the wideband for tuning/reference.
      I've had good luck with Innovate's stuff of the years.
      https://www.innovatemotorsports.com/
      Quote Originally Posted by majj35 View Post
      What ECU are you currently using? Do you want a wideband O2 sensor kit or narrow band?
      Instagram @projectgattago
      Dr. EFI
      Feb 2017
      Jeddah, KSA
      Unfortunately, not sure which. Anyway to find out?
      Are you using a GM ECU or something like Holley EFI?
      Dr. EFI
      Feb 2017
      Jeddah, KSA
      GM ecu
      GM ecu
      The GM ECUs use narrow band O2 sensors. If you want the gauges to match, you can get one of the Autometer wideband gauges:
      https://www.autometer.com
      GO to Gauge type and select "air fuel ratio."
      You will need to add a bung to your exhaust to mount the O2 sensor.
      Dr. EFI
    Tags for this Thread
