View Full Version : Ls3 tick
Sinnister69
04-24-2021, 04:40 PM
Hey guys brand new crate ls3 holley terminator x. Tuned by Andrew. Everything was great until i started break in procedure according to gm paperwork. Holding at 2000 rpm it developed a ticking noise
It has tsp stage 3 cam with springs and 7.4” pushrods.
Also oil pressure while idling goes from 28-29 psi cold to about 24 psi when at operating temp.
I am using driven BR30 oil for break in
Any input will be greatly appreciated
https://youtube.com/shorts/WV5muNZxOAg?feature=share
65 drop top
04-24-2021, 11:14 PM
Do not run it again, any potential metal shavings will destroy it. But first, you confirmed that it’s not an exhaust leak? If it’s not, I would start by checking rocker arms. Find a loose one, then diagnose why. To me, it didn’t sound too deep down, like a rod knock. Also some like to cut open the used oil filter to make sure there are no metal shavings, although I think you may see some normally upon break-in.
dhutton
04-25-2021, 05:44 AM
See if CamaroAJ will listen to it. He’s a world class GM tech and he’s probably heard that before.
Don
Sinnister69
04-25-2021, 10:42 AM
Not an exhaust leak i will message AJ but it seems he hasnt been active in a few months
icemanrd19
04-25-2021, 12:55 PM
Whenever I switched to a stage 2 tsp, dual valve springs 660 I think and push rods mine did the same thing. Still does 20,000 miles later and runs solid. Your fine
dhutton
04-25-2021, 01:02 PM
Did you measure piston to valve clearance when you installed that cam? Who spec’d the pushrod length? Did you check the wipe?
High lift LS camshafts do have a sort of sewing machine sound to them. Hard for me to tell if that’s what you have in your recording.
Don
Bad Bowtie
04-25-2021, 02:17 PM
Ain't no way that's normal :hmm::injured: The tick sounds worse as you hold rpm's on it and the oil pressure seems low as well. I would say off with the valve covers and start there.
BB
Sinnister69
04-25-2021, 05:14 PM
Gonna do that this week
Sinnister69
04-25-2021, 05:58 PM
When i first started car it was fine gave it a few revs and nothing shut it off then a few min later started it again and it was quiet then the ticking started as i gradually increased rpms
Shut it off then started it again a few min later and no ticking until i revved it again.
Seems intermittent. But is it possible the stock lifters cant handle the springs?
Sinnister69
04-27-2021, 06:37 AM
Is this a sign of a bad lifter, low oil pressure, or just bleed down from sitting gor a few days?
https://youtube.com/shorts/D1ptnYOJb8s?feature=share
Hotwire
04-27-2021, 11:47 AM
That sir is a sign of a bad lifter. With that much movement I'd take a guess that you lost the roller. If it's an AFM engine then you just have a collapsed afm lifter. But that looks middle of driver's side? So most likely not AFM.
If you have a bore scope pull the rocker and pushrod, then look down into the pushrod hole. The pushrod cup should be pushed up against the retainer clip.
Sinnister69
04-27-2021, 12:18 PM
Thank you when i was pushing down it was still springing back up so the lifter plunger seems ok. This is a brand new crate motor this was probably the 4th time it was fired up. Car is not ready to be driven
icemanrd19
04-27-2021, 03:35 PM
actually after listening to that again yours is much worse. Mine doesn’t sound like that.
Hotwire
04-28-2021, 04:56 AM
Unless it has some aftermarket lifters in it, that isn't normal. Factory lifters are usually pretty solid. That's just one of the lifters that's loose, correct? All the others are solid feeling?
Sinnister69
04-28-2021, 05:35 AM
They are all tight down in the safdle it isnt a loose bolt issue. Some i cant push others i can at varying amounts. Im guessing the lifters are just bleeding down
I did notice black marks underneath by the header collector i have the exhaust rigged for tuning purposes only. Could that make a tick noise or is it too far down 187688187689
dhutton
04-28-2021, 09:17 AM
Pretty sure your lifters aren’t bleeding down. They should have a preload on them, they should not be loose....
Don
protour_chevelle
04-28-2021, 12:48 PM
did the cam come pre installed? Id unbolt the rocker and look at the push rod, see if theres any damage to it? Im wondering if the push rod wasn't seated and it bent the push rod/damage the lifter.
Sinnister69
04-28-2021, 05:30 PM
No i did the work new springs upgraded rocker trunions everything was meticulously put together
The exhaust pipe is pretty stiff. U can see i used safety wire to tie it up and with the cam the engine rocks alot while idling. Maybe the tick is coming from the header collector that may have worked loose
I will see on saturday
protour_chevelle
04-29-2021, 03:38 AM
Sounds internal to me and that rocker suggest the head has to come off and its lifter related.
dhutton
04-29-2021, 04:23 AM
https://www.enginelabs.com/engine-tech/engine/tech-tip-checking-setting-lifter-preload-ls-engine/
Sinnister69
04-29-2021, 12:04 PM
I also didnt hear it when i pulled the valve covers
Hotwire
04-29-2021, 12:11 PM
Considering you can easily push the lifter down with a finger, your engine is missing, and you can clearly hear its internal mechanical noise, it's a lifter man, not exhaust.
Trust me, was just in your shoes. Had 14 lifters that would support my weight and 2 that compressed with a screwdriver. I couldn't move the pushrod cup with my finger at all.
https://flic.kr/p/2kV3vxq
Stop by any parts store you want, ask to examine a lifter for your car and feel how tight the spring is in the push rod cup..
protour_chevelle
04-29-2021, 12:50 PM
I agree with you 100%
Sinnister69
04-29-2021, 01:29 PM
Does the ls3 have all equal length head bolts? Im looking at arp head bolts and there are a few different sets
Hotwire
04-30-2021, 02:28 AM
Anything after 2004 has equal length.
Sinnister69
04-30-2021, 03:35 AM
Thank you i found them
Sinnister69
04-30-2021, 03:37 AM
Im guessing the lifters faiked because they couldnt handle the 400+lb open pressure springs?
protour_chevelle
04-30-2021, 04:05 AM
What are the cam specs? Guys are putting grossly oversized cams into literally stock 4.8/5.3/6.0 trucks with just springs and pushrods and spinning them to the moon with zero issues.
I think you just had a bunk lifter to start with.
Sinnister69
04-30-2021, 05:31 AM
Its a texas speed stage 3 with 111 lsa
Dont know the rest off hand but i put pac dual springs that have 400lb open pressure
dhutton
04-30-2021, 08:30 AM
https://www.texas-speed.com/p-5762-tsp-stage-3-ls3-na-camshaft.aspx
Hotwire
04-30-2021, 10:58 AM
https://ls1tech.com/forums/generation-iii-internal-engine/101521-what-spring-pressure-does-stock-lifter-fail.html
What I found looking. I'm right on the edge with my single PAC1218 springs.
That cam is going to beat the hell out of your valveguides, that's a LOT of lift. I would say contact TSP and see what they would do to make your valvetrain last, but unless you own a racetrack or youtube channel you won't get a reply from them.
Sinnister69
04-30-2021, 02:00 PM
I may just downgrade to a gm hotcam lol
Sinnister69
05-13-2021, 04:30 PM
I just recieved my johnson lifters and on one or two of them i can push the plunger a little with a pen
andrewb70
05-14-2021, 09:07 AM
That's normal. You should soak them in motor oil over night before you install them.
Hotwire
05-14-2021, 09:35 AM
Little bit of handy garage knowledge, 16 lifters will fit in a quart bottle of oil. :geek:
https://static1.pt-content.com/images/pt/2021/05/51139735771_e5c75db8be_c-1.jpg
Sinnister69
05-28-2021, 12:05 PM
What is this?
Did you just seriously join a forum and your only post is ...?
dhutton
05-28-2021, 01:59 PM
What is this?
Spammer
Sinnister69
06-26-2021, 09:39 AM
Finally pulled one head cam looked good as i spun it around. But my valves ever so lightly hit the pistons. Good thing is the valves arent bent and seat fine
189991189992
dhutton
06-26-2021, 12:38 PM
Always a good idea to check PTV clearance when swapping cams. That’s why I asked way back in the beginning of this thread. There is a ton of information out there on how to do it. The springs etc are cheap.
Don
Sinnister69
06-26-2021, 01:35 PM
Just pulled passenger head and only piston #2 has the same mark on the intake
Sinnister69
06-26-2021, 01:39 PM
Also is there a difference what direction the ouling hole in the lifter faces?
Hotwire
06-26-2021, 04:42 PM
Your rod bearings might have a little extra clearance for that to be happening. Get some rubbing alcohol and fill the combustion chamber, that helps in seeing if the valves are sealing.
The oil galley is drilled under the lifter bores, so I usually face them down into the galley. Don't think it really makes a difference though. It's more about hydraulic pressure than anything.
Sinnister69
06-27-2021, 08:50 AM
Is that notmal?
dhutton
06-27-2021, 09:10 AM
You need fly cut pistons with that cam imho.
Don
Sinnister69
06-27-2021, 09:15 AM
Besides the obvious tsp never really states or doesnt state at all what needs fly cutting.
But im gonna go with a smaller cam
dhutton
06-27-2021, 12:41 PM
That absolves them of any liability. I don’t do a lot of cam swaps but I generally check PTV clearance if lift is higher than stock.
Don
ryeguy2006a
06-28-2021, 10:43 AM
I'm super happy with my Summit Cam. I went with the 8715 "Ghost Cam" and it runs great in my car. Great sound at idle, and lower lift so much less of a chance of this happening. Thanks for keeping us updated on your situation. Bummer that happened...
Sinnister69
06-28-2021, 11:15 AM
No problem and yea it sucks. I heard good things about the ghost cam
Im looking to get something tailored to my car.
Gonna go with a cam from cam motion
Hotwire
06-29-2021, 03:23 AM
Is that notmal?
What pistons hit? Are they on the same journal?
If your valves didn't take the hit then definitely get a piece of glass or a mirror (something FLAT) and check your pushrods by rolling them across the surface. I have a cheap glass square from home depot that I use, comes in a cardboard package that you can store it in when not using it. You have to be critical looking at them to be sure they aren't bent. There's a lot of energy needed to ding the piston, it had to be absorbed by something.
Hate to hear you had a contact, but glad it wasn't anything more critical.
Sinnister69
06-29-2021, 03:34 PM
Pistons 1,3,5,7 and2 hit
4,6,8 are fine
Sinnister69
06-30-2021, 11:16 AM
Anyone know where i can get stock ls3 beehive retainers? I tried summit and jegs but cant seem to find any
Hotwire
06-30-2021, 05:10 PM
Texas speed? Brian Tooley Racing? Tick Performance?
Sinnister69
07-01-2021, 04:41 AM
Im lookin for the correct specs for the springs that come in a cam kit
Sinnister69
07-02-2021, 11:14 AM
After researchin summit offers their 8707 cam in 3 kits. One kit uses trick flow beehive springs with 318lb open spring pressure and the other two ise dual spring with 425lb open spring pressure
My pac springs have 415lb open spring pressure. Closed spring pressures are the same
So would you huys agree that i can use my pac springs?
Sinnister69
07-12-2021, 04:58 PM
Turns out that my valves did not hit the pistons.
When i was changing the valve springs i would forget to open the air line to keep cylinder pressure on the valve so the 1” or so they fell left a mark. I confirmed this by taking one of my valves and dropping them from a 1” height and it left the same mark. Pistons are pretty soft imho
Sinnister69
07-28-2021, 04:32 PM
Further investigating since everything looked immaculate i have a feeling an injector is stuck open thinning out the oil and causing the pressure to drop causing the ticking
Oil filter was almost like water
I have the tsp cam for sale in the forum classifieds
Sinnister69
09-07-2021, 09:17 AM
Fired up the car started the first time. Tune def needs to be tweeked. I checked all the injectors for any leaks and they were fine
Engine oil was 45psi at cold idle settled down to around 39-40psi after it warmed up to operating temp. And no ticking besides the normal sewing machine noise. But even that got more quiet after it warmed 191914
https://youtube.com/shorts/vYgBSKQX8ro?feature=share
Sinnister69
09-14-2021, 11:49 AM
Eh nobody cares lol
dhutton
09-14-2021, 12:34 PM
I care :lmao:
Don
