View Full Version : Oil catch can
Sinnister69
03-30-2021, 07:41 AM
Hey guys wondering if i can get some input if i installed my catch can correctly. I have the “out” port connected to the port right behind throttle body and the “in” port connected to passenger valve cover.
Valley port and driver side valve cover are capped
I have been hearing that the valley port must be on vaccum
Any suggestions or help is greatly appreciated
Engine is an LS3 of course lol
186461
Sinnister69
03-30-2021, 02:20 PM
Nvm i went with a mighty mouse can and they have detailed instructions. Mine was totally wrong :)
dhutton
03-30-2021, 03:32 PM
186461
That sounds wrong. Catch can replaces the corrugated hose between the throttle body and valley cover. In connects to the valley cover, out to the throttle body. Fresh air feeds from the intake tube (between the MAF and throttle body) to the valve cover.
Don
Sinnister69
03-30-2021, 05:23 PM
Thanks don im running the holley terminator x system. I dont have a maf sensor in the intake tube. Only a map sensor after the throttle body.
dhutton
03-30-2021, 05:43 PM
Ok so you can get the fresh air from anywhere you like. But you need fresh filtered air to the valve cover.
The way you have it plumbed now has no fresh air supply. That’s not good....
Don
Sinnister69
04-24-2021, 04:42 PM
Got the mighty mouse catch can all hooked up187541187542187543
dhutton
04-24-2021, 05:00 PM
:confused:
Don
Q; wouldn’t it work putting it inline between the pcv and the intake (I’m working with a TBSS intake and am assuming the LS3 intake has a similar setup)?
tmcmillan5
08-05-2021, 05:48 AM
Same question as Tots above, and that's the way I have my tbss plumbed now.
