    Results 1 to 7 of 7
      Germany
      Which type of brake fluid
      Hello!
      For my first brake system overhaul I used a "special US" DOT 3 fluid. The warehouse told me that this fluid is necessary, not using european DOT 3. At this time it was no problem, because I ordered a few other things.
      No I have some changes at my break system and want to use "normal" fluid=> What is your experience?
      Perhaps DOT 5 is possible?
      Night Rider => My car
      69'Camaro
      92'Corvette LT1 engine, 4L60, shorty headers, Flowmaster, Eibach, Vette wheels=> soon coming:hotchkis leaf springs nova rear w limited slip, Corvette brakes
      montgomery, IL
      if you use the silicone based fluid you need to flash the system and change your seals and boots (any thing rubber) because it will eat through it. and dont mix the two fluids.
      Jun 2005
      Bentonville, AR
      If you are willing to flush the system...DOT5 is the way to go. The dot 5 will not eat paint.
      NY
      The needs of the many outweigh the needs of the few.
      I use Valvoline Synpower synthetic in all my brake systems and have never had any problems at all. The wet boiling point is 343 degrees. Unless it's a severe duty track car, I can't see the need for anything with a higher boiling point. If so, try Wilwood brake fluid-I remember reading its boiling point was 500 degrees wet. -Jabin
      Gmachinz Sales and Performance
      "updating the level of performance..."
      [email protected]
      *never argue with an idiot-they'll drag you down to their level and beat you with experience!*
      Sep 2001
      Accord, NY
      Castrol LMA DOT4 or NAPA Blue DOT4 are both good.
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Sep 2004
      Motor City
      Unless you're into autocross, the Valvoline Synpower is the best bang for your buck.
      Mike
