    Results 1 to 20 of 31
      Oct 2017
      What are the most comfortable seats for a 69 Camaro ?
      I drive my car on backroads and will do a 100+ miles each time so what is your opinion on the best all around seat for comfort, lateral support and quality ?
      I had Procar Rally seats in my car which fit great, fairly comfortable and had the perfect seat height and slid back really far ( i'm 6'2 ) but the wore out quickly
      the side bolster foam broke from getting in and out sliding over it. So I wanted to buy a higher end seat and bought a pair of TMI Sport XR which fit terribly, too tall and not all that comfortable plus spent several hundred getting the seat base foam cut down along with the mounts.
      I'm looking for a great pair of seats that fit without modification along with great mounting brackets. Any first hand suggestions ?
      Thanks ... JT
      Oct 2007
      Hi Jake.. how about procar elite?
      Recaro Specialist if you can find them are probably you best option.. but after waiting 3 months then the order failing like 5 times I gave up ... this was during covid peak and during recoro facility move.. so you may have better luck now..
      67 Camaro In progress
      Oct 2017
      Thanks i'll look at the Elites ...
      Feb 2018
      Southern IN
      Recaro seats with Planted Technology seat mounts. Not inexpensive but checks all your boxes. I’ve got the Specialist M’s in my 68 Camaro and love them. I’m 6’ and have plenty of room overhead and front to rear. Planted mounts are very low profile and disappear once in the car so they’re basically invisible
      Shane
      #theanchorholds
      68 Camaro build thread:
      http://lateral-g.net/forums/showthread.php?t=56387
      Feb 2007
      Tinley Park, IL
      I'm also interested in this topic. I have Corbeau A4 micorsuede wide, and while I consider them to be comfortable overall, the bolster on the base digs into my right thigh and gets annoying on longer trips. I'm not sure if I want a seat with a shorter bolster, or a larger one? My thinking on a larger bolster is it will spread out the pressure of my leg over a larger area and as a result be more comfortable. But then a larger bolster makings getting in/out of the car more difficult.
      I'm looking at the Corbeau RRS, RRX, and Sparco Chrono Road.
      Braum has some nice looking seats as well, but not much info out there on quality and comfort.
      I'm just a touch over 6'5", so a low seat base is very important. I also prefer cloth or microfiber, at least in the center section.
      https://www.racing-seats-usa.com/spa...lter=undefined All cloth
      https://www.racing-seats-usa.com/cor...l?swatch=74901 No cloth options
      https://www.racing-seats-usa.com/cor...l?swatch=55022 I'm digging the plaid cloth center!
      Nick ~
      1969 Cutlass
      Oct 2017
      Shane,
      I really appreciate this. All the money spent on the car not to have great seats. Thanks ...
      - - - Updated - - -
      - - - Updated - - -
      Good looking options Nick ...
      Oct 2007
      i have a set of planetd mounts unused.. One has a few tack weld on it.. from mock up other untounched.. if you need them 50.00 plus shipping..
      bought them for the recros that never showed up..
      Oct 2017
      I'll take them ...
      Jacksonville, FL
Size:  1.91 MBI am having a similiar experience with the Procars and don’t want TMI ones. I lucked out and found a set of Recaro Specialist on FB Marketplace for $300. Needed recovered anyway. Just have to search for them.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Oct 2017
      very cool ...
      Feb 2018
      Southern IN
      [QUOTE=JAKES1969;1353226]Shane,
      Anytime, sent you some additional info via PM...
      Shane
      #theanchorholds
      Oct 2011
      The 5th gen Camaro recaro seats are very comfortable. I think your best bet is find a comfy seat in a car then buy it on eBay. All these aftermarket seats I don’t think are on par with quality as oem seats. Plus you’ll get features like power, way more adjustments and maybe heated/cooled.
      Here’s what the Camaro Recaro look like:
      https://www.camaro5.com/forums/showthread.php?t=311781
      Sep 2016
      Bakersfield, CA
      Quote Originally Posted by Gmachine1911 View Post
      ^^^This. I have Recaro Sportsters with Planted mounts and now have 2 more inches of width at the thighs over the previous sport seats I had (Sparco Chrono) which make a big difference for me when using the clutch pedal and getting in and out. I have the Recaro sliders too so there is the added height of that but it's not a problem because the bottom cushion angles down towards the rear so much on these. The seats will still lean all the way forward for back seat access and not touch the sun visors even tho they have a full headrest. Due to their narrower design, I have MUCH better visibility when backing up.
      I tried 4 different seats and these are the only ones I found as comfortable as the stock seats for long drives but have all of the added sport seat support. Plus they don't look like a giant recliner in the car compared to some TMI or Procar seats. The thigh bolster is high and requires caution when getting out so you don't cause excessive wear, but is no problem at all getting in.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
      Feb 2007
      Tinley Park, IL
      Quote Originally Posted by anguilla1980 View Post
      What size Sparco Chrono's did you have?
      Nick ~
      1969 Cutlass
      Oct 2017
      Great looking seats I ordered a pair of Specialist M's. Do you know the difference between yours and the M's ?
      Sep 2016
      Bakersfield, CA
      Quote Originally Posted by Mr Nick View Post
      The P/N is 00959CRMSKYNR - which I believe is the standard. Because I have the Morris 3-pt seat belts, I was warned the Large would be too wide to accommodate the retractor. Even with the Recaro Sportsters I needed to buy special slimline recline adjustment knobs.
      Feb 2007
      Tinley Park, IL
      Yes, you had the "Medium" size, the larger size does not have "M" in the model number. My Corbeau A4 wide is very close to the Morris seatbelt retractor as well. I didn't think of that. something else to consider while shopping!
      Nick ~
      1969 Cutlass
      Nov 2018
      Winchester, KY
      Takes modifying but the 04-06 GTO seats are the most comfortable of any car I’ve been in(Volvo,BMW etc) and with power all in them. In my project: https://www.pro-touring.com/threads/...04-GTO-LS1-man I’m 6,1 and 170 and these seats could easily support 300lbs; rugged frames.
      Oct 2015
      Western Mass
      I've only sat in these on the floor, but even without the power lumbar hooked up, the 2000 Trans Am seats feel great. Seat's have power air lumbar bolsters bottom and back. Wrinkles show no power for a few months of sitting in the storage shed.
      I'm probably gonna go with the straight perforated pleat rather than the diamond (I photoshopped that) but I have to decide soon, dropping them off in a week. These pix show them as normal look.
      Might also carry the perf material over the front center with or without the pleats.
      Rear "design study"
      You might've guessed by now... I have a white interior and I love it.
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
      Sep 2020
      Quote Originally Posted by OldTimer View Post
      Rear "design study"
      Did you get yours done yet, in white? Photo would be appreciated.
