View Full Version : 67 Camaro LS2 Silicone Radiator Hose?
1967ls2
01-21-2021, 08:18 PM
Can anyone recommend a silicone radiator hose combo that will work with this setup? I'm running an LS Entropy radiator with both Inlet & outlet on the passenger side. Thanks in advance.
130fe
01-22-2021, 05:44 AM
Silicone or rubber (if it matters)? Which side is your water pump hose fitting on? Drivers or Pass side?
badazz81z28
01-22-2021, 12:30 PM
May I ask why you want a ~$100 each silicone hoses?
79 Camaro
01-23-2021, 02:54 PM
Just FYI. On the C10 forums a guy that had a similar issues as above. He used an ICT thermostat adapter to use a Billet Specialties small block thermostat housing. The ICT adapter uses a LS thermostat. Looked pretty cool.
