View Full Version : Varishock coilover, spring hits shock body
VenturaII
12-27-2005, 03:34 PM
Is it normal for the spring hit the shock body when a coilover is compressed?
12-27-2005, 11:08 PM
No.
Are the springs 2.5" ID?
Do the lower spring seats have an inner ridge to keep the coils centered?
VenturaII
12-29-2005, 06:32 PM
Yes, they are 2.5" springs and the lower spring seat has a lip that holds it centered. 200 lb spring on a shock with right at 5 inches of stroke. When the shock is compressed several inches the spring lightly contacts the side of the shock body.
12-29-2005, 09:09 PM
I"d try flipping the coil over.
If there is much side force on the shock body, the shaft and seal can wear out faster.
It could be a bad spring, I've seen them bend to one side and rub but the better springs won't do that.
VenturaII
12-30-2005, 08:40 PM
OK, I'll try flipping it over. Thanks.
