View Full Version : Help converting a 69 camaro standard to RS
71maroesteban
01-17-2021, 10:39 PM
Okay so my car was originally a standard run of the mill 69 camaro, I would like to convert just the front end to a RS front end. I’ve read some places the fenders and inners need to be replaced others say you don’t need to do all that? I have speedtechs deep front tubs for the extreme frame do I need to modify them to run the hideaways? Also I was planning on using the DSE motors
dhutton
01-18-2021, 04:29 AM
I prefer the Retro Electro RS kit over the DSE. I’ve installed both. The DSE is a bit of a kludge imho. I have Anvil inner fenders and did have to drill a hole in them. You can use standard fenders by attaching brackets if yours don’t have them.
Don
Bad Bowtie
01-18-2021, 05:19 AM
Don
I'm with Don on the headlight motors... Retro Electro kit is much simpler I have used two kits with out any issues.
You can also get these adapter for the fenders.
1969 Camaro Rally Sport Fender Conversion Adapter Brackets, Pair (camarocentral.com) (https://www.camarocentral.com/1969_Camaro_RS_Fender_Headlight_Adapter_Brackets_p/ral-6.htm)
BB
Just 1 More
01-18-2021, 05:55 AM
3rd for the Retro-Electro although I have a 68 but they were great to install
71maroesteban
01-18-2021, 06:23 PM
Don
Does the retro kit come with a template on where to cut the inner fenders such as the DSE?
Bad Bowtie
01-19-2021, 01:34 AM
Not sure if they included templates for 69RS. I did 67 & 68's.
Here is the instructions...
Retro-Electro instructions, PN-004 (retro-electro.net) (https://retro-electro.net/69instruction.html)
BB
dhutton
01-19-2021, 04:49 AM
You just have to drill one hole, not very complex. It’s just a clearance hole for the motor, position is not critical.
As I said, the Retro Electro solution is simpler and more elegant than the DSE imho...
Don
71maroesteban
01-20-2021, 09:40 AM
Don
Thank you for the insight Don. I’ll go ahead and do the retro electric
