View Full Version : An6 fittings from hard to flex lines
absintheisfun
01-11-2021, 06:11 PM
I've been searching, and it seems that there are two different -AN styles for hard lines. Compression fittings that use a brass ferrule and the 37 degree flare type. Is one better than the other?
Thanks!
icemanrd19
01-11-2021, 09:02 PM
I used a tube and flare.
Motobrewmaster
01-12-2021, 05:13 AM
I have had good luck with the 37 flare fittings. Get a good flaring tool and you should have no problems. Also do not use seamed tubing
Tsaints1115
01-12-2021, 07:55 AM
Depends on what your doing but I have used both.
andrewb70
01-12-2021, 09:06 AM
Thanks!
I made this video 5 years ago:
https://www.youtube.com/watch?v=46hFmkTGGV8
Shows you everything that you need.
absintheisfun
01-12-2021, 05:27 PM
Thank you for the input. I have a good flaring tool and had planned on going that route-it was only recently i learned of the other type. Just wanted to make sure I was still good with the 37 flare.
badazz81z28
01-14-2021, 02:52 PM
I would use a 37 degree flare over a ferrule. It all comes down to proper prep and a quality flaring tool!
andrewb70
01-14-2021, 03:23 PM
My video shows everything you need to know, including the tool, which, as I recall, wasn't very expensive.
I have used both and they work great
protour_chevelle
01-15-2021, 05:25 AM
Both ways work. I prefer the stainless industrial brand compression fittings like swagelok
torino420
01-23-2021, 07:44 AM
Yup, this is what i used. https://www.ham-let.com/catalogue/product/14364
