    Results 1 to 11 of 11
      Oct 2006
      McKinney, TX
      An6 fittings from hard to flex lines
      I've been searching, and it seems that there are two different -AN styles for hard lines. Compression fittings that use a brass ferrule and the 37 degree flare type. Is one better than the other?
      Thanks!
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Feb 2011
      dallas, tx
      I used a tube and flare.
      Jan 2014
      Portsmouth NH
      I have had good luck with the 37 flare fittings. Get a good flaring tool and you should have no problems. Also do not use seamed tubing
      Feb 2019
      Kankakee IL
      Depends on what your doing but I have used both.
      Tracey
      Quote Originally Posted by absintheisfun View Post
      Thanks!
      I made this video 5 years ago:
      Shows you everything that you need.
      Instagram @projectgattago
      Dr. EFI
      Oct 2006
      McKinney, TX
      Thank you for the input. I have a good flaring tool and had planned on going that route-it was only recently i learned of the other type. Just wanted to make sure I was still good with the 37 flare.
      My build Beast
      Jun 2010
      Deployed
      I would use a 37 degree flare over a ferrule. It all comes down to proper prep and a quality flaring tool!
      1970 Camaro/DSE build
      My video shows everything you need to know, including the tool, which, as I recall, wasn't very expensive.
      Dr. EFI
      Lawrenceburg, TN
      I have used both and they work great
      Red Deer, Alberta, Canada
      Both ways work. I prefer the stainless industrial brand compression fittings like swagelok
      Matt
      Instagram: Cst_koon
      May 2007
      Quote Originally Posted by protour_chevelle View Post
      Yup, this is what i used. https://www.ham-let.com/catalogue/product/14364
      69 Torino GT Formal Roof
      420" W - TKO 600
