    Results 1 to 2 of 2
      Jul 2018
      FRONT , What's the widest 18" on a stock sub
      1968 Camaro, tubular upper & lowers & Coilovers, I've got 245-45-18 on it now. What have you guys found to be the biggest (widest) tire you can fit on a stock subframe and what are some of the tips, tricks and modifications to get them to fit? For example, I've seen where you replace some of the inner fender bolts with button heads, what else?
      Lawrenceburg, TN
      tube arms and coilovers dont increase tire clearance.....
      245-35-18 or 255-35-18 on an 8 inch rim on stock frame with stock spindle and stock steering arm....
      275-35-18 on a 9.5 rim with 5.5 backspace using the ridetech tru turn upgrade
