View Full Version : 2.5 vs 3
1985olds
10-22-2020, 10:13 AM
Good afternoon everyone,
I broke a hangar on my exhaust and unfortunately, I think that might be the last straw for this system.
Car is a g body with an NA LS3/tremec magnum. On the dyno the car made 500.1/475 at 5900/4xxx to the tire through a 2.5" exhaust.
Now that its time to redo the exhaust, I'm looking for opinions on 2.5" vs 3" pipe. Thank you
Lonnies Performance
10-22-2020, 12:46 PM
At your power level a 3" should be of benefit, but I'm not sure what system you presently run or the noise level you are accustomed to.
3" pipes tend to be louder, so there is a tradeoff.
1985olds
10-22-2020, 02:38 PM
Thank you. Current system is 2.5" with an x pipe and borla pro xs mufflers, exiting behind the rear tires
68Formula
10-22-2020, 04:17 PM
Run 3" through the mufflers and then reduce to the 2.5" tailpipes you already have. Will make the same power with less increase in noise (assuming you also run an X pipe and 3" Pro XS mufflers).
