View Full Version : Terminator x max
Sinnister69
10-19-2020, 10:08 AM
Regarding the oils pressure sensor on my ls3. The terminator harness plug for that sensor doesnt match.
Can i just get the bare plug for my sensor and put it on the terminator harness without spending 137$ for the holley sensor?
icemanrd19
10-19-2020, 07:12 PM
Thank me later lol
https://lowdoller-motorsports.com/collections/pressure-sensors?fbclid=IwAR0YkAlj3mpHa69Z5J-wz1at6fpHMnbPeKuEZyP7WfMeU97k9HbLdanUiuM
Sinnister69
10-20-2020, 04:53 AM
Thank me later lol
Im using stock sensor that came with ls3
Just changing the plug.
I have the plug $2.00 from wiring specialties
andrewb70
10-20-2020, 05:35 AM
What is the sensor that comes with the LS3?
I use ACDelco D1846A and it plugs right into the Holley harness. It does need a custom sensor configuration.
If I can be of help with the tuning, please let me know.
Sinnister69
10-20-2020, 06:37 AM
Thanks andrew yes thats the one that comes stock. This is the oil sensor plug on my terminator
180382
andrewb70
10-20-2020, 06:56 AM
180382
That connector fits that sensor.
Sinnister69
10-20-2020, 07:17 AM
Hmm maybe i didnt try hard enough lol
But i do know the map sensor plug doesnt fit either
andrewb70
10-20-2020, 07:45 AM
Which map sensor are you using?
Sinnister69
10-20-2020, 08:03 AM
Everything is stock
Is there a gm 1bar that goes into stock ls3 so i dont have to run a vacuum line to the ecm?
andrewb70
10-20-2020, 08:24 AM
Everything is stock
Holley sells the 558-416. It is a LS1 to LS3 MAP harness adapter.
Let me know if I can be of service to help with wiring and tuning.
Sinnister69
10-20-2020, 09:02 AM
I kinda dont want all these extension harnesses in my wiring. I can just get the plug and replace it
andrewb70
10-20-2020, 09:12 AM
If you got the wiring mojo to do that, then I highly recommend you do that. It is the best option. Be mindful of the pinouts between the ls1 and ls3 map sensors. They are not the same.
Sinnister69
10-20-2020, 09:24 AM
Yes thank you
Sinnister69
10-20-2020, 03:48 PM
Can a MAT sensor be installed where that port is coming out?
It looks removable
180394
andrewb70
10-20-2020, 05:07 PM
It looks removable
180394
I generally recommend putting the MAT sensor into the intake tube, ahead of the throttle body.
Sinnister69
10-21-2020, 09:37 AM
Will i have to drill into tube is there a good intake system that has MAT provisions
andrewb70
10-21-2020, 09:42 AM
You can drill into the tube and tap it for 1/2" NPT. There is also an alternative sensor that slips into a rubber grommet, so you can make a hole in silicone elbow ahead of the TB.
Sinnister69
10-22-2020, 06:09 PM
Thanks i will do that
Anyone know if you can program a vss into one of the i/o ports?
andrewb70
10-22-2020, 06:59 PM
Yes.
Sinnister69
10-22-2020, 08:33 PM
Yes.
Is there a good link on how to set it up?
I have a tko 600 and dakota digital guages. I do have the dd holley bim module
andrewb70
10-23-2020, 03:11 AM
Use pins 14 and 18 on the J4 connector and enable the trans off.
