View Full Version : Backspacing for a square setup
spazegun2213
10-13-2020, 09:02 AM
Alright guys, I'm doing things a bit backwards and letting my wheels define rear axle width.
My have a '71 Fbody subframe from Speedtech, and I'm using their rear TA setup with DSE mini tubs.
So my question to you all is if I wanted to run a square 315/30/18 setup what are the backspacing numbers I should be looking at?
dontlifttoshift
10-13-2020, 01:06 PM
It's not backwards, it is the right way to do it. I did the same with my Camaro, actually had to widen the stock axle housing in my case.
Figure out what fits in the front. Order 4 of them. Put them under the car where they need to go and then build your axle.
Did you mean 315/30-18?
spazegun2213
10-13-2020, 02:03 PM
sounds like what I'm trying to do :)
and yes, 315/30R18...
dontlifttoshift
10-13-2020, 02:36 PM
So your question is what backspacing should I run with a SpeedTech eXtreme front subframe?
I would think speedtech could provide you with an actual backspace number and wheel width for their front suspension.
redbull396
10-24-2020, 06:55 AM
When you say "square", do you mean same size wheels on all 4 corners? I keep seeing this term, but not sure what it means, lol. Thanks in advance.
Rod
10-24-2020, 06:53 PM
same wheel and tire size front to rear, and front to rear track width as close equal as possible
