View Full Version : Help - UMI
pro86tourn
07-10-2020, 08:48 AM
help/advice please... I put the wheels on for the first time today and noticed that the lower control arm is like a 1/16'' away from the brake rotor (willwood) ... Anyone else run into this issue or have an idea if this is okay, seems like when the suspension travels it will make contact with the rotor.
Called UMI and left a message
any ideas?
dhutton
07-10-2020, 10:37 AM
Is that at ride height with correct camber?
Don
pro86tourn
07-10-2020, 05:12 PM
no, suspension has yet to be aligned but pretty close to ride height
dhutton
07-11-2020, 05:59 AM
I am not positive but adding some shims to get negative camber should gain some clearance. Do you have any shims installed?
pro86tourn
07-12-2020, 04:40 AM
No shims yet
ford396
07-12-2020, 05:51 PM
Could clearance lower control arm or shim behind wheel bearing a little. It does not take much clearance there to be okay.
