View Full Version : ridetech CoilOver System
Shotaro
06-06-2020, 02:50 AM
I installed a CoilOver System on the 1969 Mustang. Do you have a matching minitub?176581
dhutton
06-06-2020, 03:23 AM
Detroit Speed has minitubs for that car.
Don
Shotaro
06-07-2020, 05:15 AM
Don
There was an explanation that the Minitro of Detroit Speed ​​cuts the frame. Ridetech's coil over mount is attached to the frame.
thank you
Rod
06-07-2020, 05:47 AM
thank you
the mini tub kit only removes part of the frame rail... the outer part the ridetech cradle mount to the inner... you only have to cut a little part of the ridetech cradle
here is a picture of the narrowed frame rail and the ridetech cradle as you see only a little trim work need to happen...... p.s. don't forget well the tubs and members her get a 10% discount
176615
1bad68cat
06-08-2020, 07:43 AM
Another option is to use the Detroit Speed kit, but not do the full mini-tub. What I mean is to cut out the sheet metal only to the factory frame rail. But if you do this, maybe it would be cheaper to buy a factory reproduction wheel tub, cut the factory tub out, leaving a 1"-1.5" lip (the distance really should from the factory inner wheel tub to frame rail) for the reproduction wheel tub to butt-weld to. The downside, you can't fit as big a tire if you did the full mini-tub.
classiccarcustoms
06-16-2020, 07:07 PM
176615
That frame rail in the picture looks bent about 3” before Ridetech upper link bracket.
Shotaro
06-22-2020, 04:42 AM
Thank you very much. But I don't want to cut the frame.
GTOtzel
06-22-2020, 06:10 AM
If you want to widen the tub just to meet the rail you are still going to have to also relocate the lower link bars. Since the bar attached to where the leaf spring went on the outer side of the frame rail.
builttodrive
07-11-2020, 07:18 PM
I have the Ride Tech coil over system on my car a 1970 mach 1 and I made my own mini tub. I made the tub square and went to the frame rail but did not cut it. I did this as it was the max I could go and still keep the rear seat without having to modify it. My wheel wells can handle 315-325 tires with ease but the lower 4 link bars on the ride tech system are the limiter. I have 305's on the car now and should be able to go to a 315 wide tire but the suspension is the limiting factor.
Shotaro
11-10-2020, 07:11 AM
Is it possible to send me the attached photo? I'm thinking of buying a Detroit Speedo minitab.
