View Full Version : Ridetech Front alignment spec
keith4909
05-25-2020, 04:58 PM
Have the front upper and lower ridetech control arms with coilovers. What alignment specs for a street driven car? Thx
1967 GTO.
79T/Aman
05-25-2020, 08:02 PM
there is no given set up, it depends on what you want to do or expect but since you are on this forum I would start with 3/4-1* negative camber, 4-6 * positive caster and 1/16 total toe in, but you need to adjust to fit your application.
Josh@Ridetech
05-28-2020, 06:14 AM
The specs he listed above are right at what we recommend. From those base dimensions, it's really preference from that point.
Rod
05-28-2020, 11:55 AM
street... ¼ to ½ neg. camber, 3 to 4 pos. caster, 0" to 1/8" Toe In
Rod
05-28-2020, 12:01 PM
RACING 1 ½ to 2 neg. camber, 5 to 8 pos.caster, 1/8" out to 1/8" IN......toe out on a short autocross track with tight turns, toe in on road course
