View Full Version : 69 Camaro, Driver side window moves around a LOT
69camarokid
05-13-2020, 09:55 PM
Hi Friends.
I have a 69 Camaro and my drivers side window is able to move around A LOT.
When the window is rolled all the way up, it stops a solid 1/4" from the sop, leaving a gap for air/water. I have to open the door and grab the window and lift it up the last 1/4". It will then sta in position.
The passenger side window stays in position with no problem and does not move. It rolls up with no problems.
Im looking to figure out what is causing this problem and how to fix it? Here is a video of the door moving in action. Thoughts? Ideas?
https://www.youtube.com/watch?v=BXm0AB8rQOQ
69camarokid
05-22-2020, 06:02 PM
Just a bump incase anyone has any ideas....?
CapSS92
05-27-2020, 03:57 PM
Would this help?
https://www.youtube.com/watch?v=tjiej7cH5Fg
Alex
Z06vet
05-30-2020, 06:27 AM
The roller on the the rear track looks to be non existent or in pieces. Front is likely the same. The rollers are replaceable I believe. Here's a link to help you see what the full assembly looks like
https://www.npdlink.com/product/plate-and-roller-set-door-window-glass-lh/144260/8122
