View Full Version : Help finding correct terminal
Sinnister69
04-30-2020, 04:26 AM
Hello i have a PSI harness and i need to shorten the alternator plug. Does anyone know what female wire terminal i need?
Pics below175423
Thank you
Ps i did email psi with no response as of yet
ween
05-01-2020, 03:35 PM
Its a bosch brand connector 1928403137. Uses TE/Tyco terminals, Junior-Power-Timer is the series.
https://www.automotive-connectors.com/bosch-1-928-403-137-2-way-female-compact-connector-1-code-1-black.html?___store=english
Should be able to use that page for terminal part numbers. Tyco 929940-3 or 929930-3 or equivalent will fit. I have terminals and seals that fit that connector if you have trouble sourcing.
Sinnister69
05-02-2020, 06:04 AM
Thank you!
Tsaints1115
05-02-2020, 09:54 AM
Andrew B on here is the terminal God. He's the guy I'd ask.
Sinnister69
05-03-2020, 08:36 AM
I feel like the psi harness is mad long. Im gonna need to shorten a bunch of sensor wires like the acc pedal and cam/alt sensors just so the wires will be tucked a little better
andrewb70
05-04-2020, 06:33 AM
This is solid information...
https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/929940-1?qs=YPTlsxdWOqIG1s5DNzA32g%3D%3D&gclid=EAIaIQobChMIm67io7aa6QIVBgiICR2P1gGPEAYYAiAB EgJnYfD_BwE
