View Full Version : 69 Corvette with Rocket Attack
jimco84x
04-20-2020, 08:52 AM
This may be a bit premature since the car is still without rear brakes and can't be driven. We still need to dial in the coilovers for height and corner weights, but here is an idea of what this will be. 1969 Corvette. Van Steel Coilovers front and rear. 18x10 Rocket Attacks with 285/35R18 on all 4 corners. Don't criticize the ghetto-tastic turnplates under the front tires. :)
175023
2yellow69
04-20-2020, 09:22 AM
I use doubled over wax paper for cooking as turn plates. No criticism coming from here!! Car looks great!
vette427-sbc
04-20-2020, 12:17 PM
Those look great!
Alwhite00
04-20-2020, 05:04 PM
Nice wheels, great color on the car.
jimco84x
04-23-2020, 01:18 PM
Thank you all!!
pro86tourn
04-23-2020, 01:46 PM
awesome !
jimco84x
05-08-2020, 12:05 PM
at a more proper ride height and with the brakes actually working!!
175808
pro86tourn
05-12-2020, 08:01 AM
bad ass
STREETFIGHTER50
05-13-2020, 02:32 AM
Very nice!
Rod
05-13-2020, 04:53 PM
looks GREAT!!!
klabz28
05-14-2020, 09:21 AM
Those look awesome! Anything else done to the suspension / clearancing needed to get them to fit without rubbing, stock flares?
I'm looking for wheels for my 68 after some upcoming suspension upgrades and lowering, these would look killer powdercoated black :)
https://static1.pt-content.com/images/pt/2020/05/Krnrw1jh-1.png
jimco84x
05-15-2020, 07:08 AM
You won't get that much wheel under it without changing some stuff. I've got the full Van Steel coil-over set up front and rear with the offset rear arms. To use with stock rear arms, you'll have to relocate the E-brake and dump the rear sway bar. If you don't want to get crazy, you could probably do 18x9 with 5 inch BS with 275's. Probably still have to move the e-brake tab, but I think the stock arms and sway bar would probably be ok. I'm not sure how much wheel will fit with the stock front suspension. These tire will rub if I turn the wheel too far...so I just don't do that. Normal driving, it's fine.
Rocket racing has a custom shop that does different finishes. http://www.rocketracingwheels.com/custom-finishes/c267 Tell Rob I sent you over.
Aficionado
05-16-2020, 06:31 AM
Looking good!!!
klabz28
05-17-2020, 05:47 AM
Nice, thanks! I have no rear sway bar but sounds like the rear control arm and leaf spring will give me issues. There looks to be much more room up front.
jimco84x
05-18-2020, 04:35 AM
Relocating the E-brake tab is pretty easy if you access to a welder. If the wheels contact your leaf spring, you can get them in 1/2 or 1 inch shorter version which should give even more clearance. 18x9 with 4.5 backspacing would look the same as mine on the out side and have plenty of room on the back side. I doubt you'd even have to do the e-Brake mod. Check first though. If I hadn't sold the factory arms, I could double check for you. :(
https://www.vansteel.com/index.cfm?fuseaction=shop.ProductList&subgroup=3004
klabz28
06-05-2020, 06:52 AM
Thanks, I'm going to lower the stock rear setup with the bolts just to figure out the height and see how narrow I'd need to go on the leaf spring, relocate the ebrake tab and rent a wheel fit tool.
Do you have any direct side shots yet? Want to see how the 35 fills in the rear quarters ��
jimco84x
06-09-2020, 07:29 AM
176662
176663
klabz28
06-09-2020, 10:50 AM
Looks awesome!
ssdtrain
02-04-2021, 03:51 PM
That looks real good brah !!!
what size tires???
Restomod1968
02-18-2021, 05:16 PM
Nice, what backspacing are you running on the rear?
