View Full Version : Pro touring suburban?
CW42
04-16-2020, 09:01 PM
Lots of awesome trucks on here. Anyone built a suburban? Pre -72. Thanks.
FLYNAVY53
05-24-2020, 05:44 AM
I have a '72, but its definitely not "Pro-Touring".....more my daily driver, parts hauler, camper, etc.
'72 2wd C20. 6.0L LS, 4L65E, Holley Terminator.
176330
176331
176332
WILWAXU
05-24-2020, 10:54 AM
176330
176331
176332
Great looking truck!
FLYNAVY53
05-24-2020, 11:04 AM
Thanks....its been a really good daily for the last 7 years now. I really wish there was an equivalent forum for modified vintage trucks geared more towards off-road/overlanding type builds. I apply a lot of the stuff I've learned here to my truck but obviously the suspension type stuff doesn't translate.
Vimes
05-25-2020, 08:40 PM
You might look at https://forum.ih8mud.com/ , they come up a lot when I'm searching out technical issues for my own truck. They seem to know what they're talking about and cover suspensions from stock to Bigfoot.
Your Burb looks outstanding, but were it mine I'd convert to the GMC grill, just for the 4 headlight system. 4 individually aimable headlights work a lot better than the 2 bulb setup.
FLYNAVY53
05-26-2020, 02:27 AM
Thanks very much, Ill check it out. Its actually funny you mention headlights...I just swapped in a set of Dapper Lighting OE7s...
176407176408176409
They're obviously much brighter than factory, but if you look closely, also have an amber LED in the bottom that works as a turn signal. This will allow me to mount two 6" light bars from Dynamic Diodes in the factory turn signal cut outs.
176410
Running the GMC grille would be one option, but personally I prefer the look of the factory Chevy grille.
Gmachine1911
05-26-2020, 04:37 AM
Wow, Nice Suburban! I’ve got a similar pair of LED light bars hidden in the grill of my F-250 and they’ll turn darkness into daylight with the flip of a switch!
FLYNAVY53
05-26-2020, 08:25 AM
Wow, Nice Suburban!
Thanks, eventually the plan is to pull the body off the frame, blast from the lower metal trim line down to address all the rust/bondo that's in the lower quarters, and convert it to a 4wd set up while the body is off the frame. This will allow me to fix the rust without doing a full repaint as I like where it is....nice enough from 10 feet, but not nice enough that I worry about driving it. For the 4wd conversion, Ill probably retain the trailing arm and coil set up in the rear for ride quality, and convert the front to another Dana 60 on leafs, along with a divorced NP205 so that I can retain the stg 2 4L65E I'm currently running. The goal is not to turn this thing into a rock crawler or anything, just make it a little more capable off road so that I can go camping in a few more out of the way places.
cla5675
05-26-2020, 05:40 PM
The Roadster Shop built an amazing 66 Suburban several years back. Here is the build:
https://roadstershop.com/galleries/1966-suburban/
Vimes
05-30-2020, 12:45 PM
Very nice. I guess the sealed beam LED replacements make the 4 headlight system not necessary then. I like that.
Smee78
06-11-2020, 06:38 AM
Looks real nice, just something cool about a 3 door vehicle.
Zspoiler
06-11-2020, 09:06 PM
A friend of mine built an 1984 Suburban that was lowered and had a Supercharged big block in it It ran 13`s in the quartermile .
Motown 454
06-17-2020, 04:51 PM
That's a beautiful truck!
Craig@Bowler
06-18-2020, 08:10 AM
If you haven't been there before, the expedition portal forum is geared towards overlanding vehicles and adventures. It covers all types of vehicles but if you're into that type of activity you'll like it.
FLYNAVY53
06-18-2020, 08:46 AM
Thanks Craig, Ill check it out.
