    Results 1 to 3 of 3
      Jun 2016
      Offset Check 18x9.5 +15mm
      Stock subframe currently (either doing a new frame or truturn)
      5x120 being redrilled to 5x4.75 (120.65) 18x9.5 +15mm.
      What spacers will I need for this car? 1969 Camaro looking for 275/35r18 square
      Mountain Springs, Texas
      A lot of variables there. Depends on your ride height, alignment and where you want it to rub. I’m going to guess around .25” or .375” spacer....
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jun 2016
      Here is the +15mm wheel on the front of the car with a 275/35r18 Nitto 555 G2.
      I dont know if i would want to space that wheel out anymore. I am hoping the true turn will center up the wheel as its touching the inner rear side of the fender alittle at full turn.
