View Full Version : Offset Check 18x9.5 +15mm
mtm87tx
04-12-2020, 09:10 PM
Stock subframe currently (either doing a new frame or truturn)
5x120 being redrilled to 5x4.75 (120.65) 18x9.5 +15mm.
What spacers will I need for this car? 1969 Camaro looking for 275/35r18 square
dhutton
04-13-2020, 05:32 AM
A lot of variables there. Depends on your ride height, alignment and where you want it to rub. I’m going to guess around .25” or .375” spacer....
Don
mtm87tx
09-30-2020, 06:41 PM
179759
Here is the +15mm wheel on the front of the car with a 275/35r18 Nitto 555 G2.
I dont know if i would want to space that wheel out anymore. I am hoping the true turn will center up the wheel as its touching the inner rear side of the fender alittle at full turn.
