Craig@Bowler
02-11-2020, 07:44 AM
Bowler Performance has recently released a clutch pedal conversion kit for the 73-87 C10 trucks, full size Blazers, & Suburbans (https://shop.bowlertransmissions.com/collections/clutch-pedal-conversions/products/73-87-c10-full-size-blazer-clutch-pedal-conversion-kit). This add on pedal kit allows you to convert a factory automatic truck pedal set up without needing to source parts from the salvage yard or buy a used carrier. The package comes with all parts needed and the bracket can be welded or bolted onto the auto pedal carrier. You can still utilize a factory mechanical or hydraulic set up for clutch engagement. There is also a new pedal pad included for the brake pedal to weld in place of the wider pad or use as a template to cut down the existing one. $325 for the conversion kit. We've also developed a complete hydraulic master cylinder conversion (https://shop.bowlertransmissions.com/collections/hydraulic-components/products/73-87-c10-full-size-blazer-hydraulic-master-cylinder-kit-plastic-reservoir) for these trucks that can be used with our new pedal or in place of a mechanical clutch linkage on a factory manual equipped truck.
172782172783172784
172785172786
172782172783172784
172785172786
