    Feb 2016
    Lawrenceville, IL
    73-87 C10 clutch pedal conversion
    Bowler Performance has recently released a clutch pedal conversion kit for the 73-87 C10 trucks, full size Blazers, & Suburbans. This add on pedal kit allows you to convert a factory automatic truck pedal set up without needing to source parts from the salvage yard or buy a used carrier. The package comes with all parts needed and the bracket can be welded or bolted onto the auto pedal carrier. You can still utilize a factory mechanical or hydraulic set up for clutch engagement. There is also a new pedal pad included for the brake pedal to weld in place of the wider pad or use as a template to cut down the existing one. $325 for the conversion kit. We've also developed a complete hydraulic master cylinder conversion for these trucks that can be used with our new pedal or in place of a mechanical clutch linkage on a factory manual equipped truck.
Size:  82.5 KBName:  pedals.jpg
Size:  41.0 KBName:  pedals5.jpg
Size:  100.7 KBName:  hydraulics 4.jpg
    visit us on the web at www.bowlertransmissions.com
    Feb 2013
    Looks great, Craig!
    Ridetech Suspsension
    Tech Specialist
    Phone: 812.481.4734
    Project Fox
    1979 Trans Am
    Apr 2002
    North Central Texas
    Nice kit. Congrats!
    Shannon
    Modo Innovations
    940-391-9002
    Feb 2016
    Lawrenceville, IL
    Thanks guys!
