View Full Version : Wilwood 7/8 master cylinder
FLYNAVY53
01-26-2020, 05:46 PM
I ended up needing a 1 inch bore master cylinder for my set up. If anyone thinks they could use this 7/8 master, its got a whopping 1 week and two test miles on it. No issue with it, 7/8 just wasn't pushing enough volume to the calipers I'm running. All of the fittings, hardware and cap are new and unused. I swapped all of the original fittings and hardware to my new master so that I could include these unused pieces with this unit.
$200 shipped.
Greg
172107
TANKMASTERJ
01-27-2020, 12:51 PM
Greg are you using a non power brake setup because I am trying to figure out what's best for my application I'm using 14 in Aero 6 in the front and 14 inch aero in the rear.
I am currently thinking I will stain on power do to help tight clearances where my master cylinder meets my speedtech down tube subframe braces
Just wondering what others are doing with similar Hardware
FLYNAVY53
01-27-2020, 02:38 PM
I am. Its a 1964 Corvette and I'm using Wilwood's D8 calipers which are Corvette specific. According to Wilwood, these calipers have a significant internal volume which is why I was running out of pedal travel and bottoming out the piston with the 7/8 master cylinder. I would call Wilwood and ask them what size MC they recommend for those specific calipers in a non power application if thats the direction you're trying to go.
