View Full Version : Touch up on Candy Colors
badmonza
01-11-2020, 05:29 AM
Anyone have this done and completely satisfied with results. I need a couple of spots looked at but really concerned with what will look like when work is complete. In Louisiana so would like to stay close by also. Any names to check with would be appreciated. Thanks.
jlcustomz
01-11-2020, 06:53 AM
Do you at least know what paint manufacturer & color codes were used? would be a helpful start. Also , are we talking minor scratches & chips, or more major?
badmonza
01-11-2020, 11:01 AM
Yes I have paint code and all. Little more major.
shelteredchevelle
01-11-2020, 11:34 AM
As much as I love the candies and 3 stage paints, I'm going 2 stage this time around because it's insanely hard to get a blend/match on touch ups. Plan on painting the entire panel and the original code you went with not matching. If you have a really patient paint man, they will tweak it to perfection, just takes a few tries. Just my .02 from my own experiences with candies and 3 stage.
jlcustomz
01-11-2020, 11:41 AM
In that case, entire panel will probably be reprimed & started over, hopefully they can work up to your stripes if needed. Then reclear panel. Perfect color & flip flop in various lighting match is never easy, but at least the color you have is far easier than a silver. Grew up in southeast La, but doubt anyone good I knew growing up is still painting or breathing.
Small spots may be able to be airbrushed & blended into panel, but likely never near perfect up close. A good panel repaint with the paint codes & mix job hopefully being close enough is usually what gets done & has a strong chance of being plenty close enough with the right painter.
dhutton
01-11-2020, 01:37 PM
Is it a tricoat or a true candy? If it’s a tricoat any quality body shop should be able to handle the repair. True candy is a whole different game.
Don
